Reload this Page >
How to install a 30-Amp RV Power Outlet with Branch Breakers
Old 07-30-19, 01:43 AM
Excellent forum for doityourselfers. Thanks
I'm swapping out a 30 Amp RV plug for a 30 Amp RV plug with two 20 amp branch breakers / outlets.
The first RV outlet I installed I used 8 gauge wire with a black white, and copper ground. The 30-Amp RV Power Outlet with Branch Breakers schematic shows a "red" wire too. I have no idea what to do now. Does anyone know what the red wire is used for? The cable I installed does not have a red wire. I assume the green wire in the schematic is ground. Thanks in advance. Please see pics. Jim
Old 07-30-19, 02:21 AM
pcboss's Avatar
Received 114 Votes on 99 Posts
According to the diagram the red is the hot to power the 20 amp gfi.
Old 07-30-19, 05:13 AM
Received 338 Votes on 291 Posts
That box is designed for 120/240 volt power input. You only have 120 volt power input. One of the breakers will not function unless you run a new cable.
Old 07-30-19, 08:22 AM
Geochurchi's Avatar
Received 96 Votes on 89 Posts
Hi, if the lugs are rated for 2 conductors ( I doubt it) then you could install a jumper between the black and where the red conductor is supposed to be installed.
Geo
Old 07-31-19, 02:48 AM
pics
Thanks to all. See pic please. Could I wire a jumper as depicted in light gray color?
Old 07-31-19, 04:23 AM
Geochurchi's Avatar
Hi, yes if that lug is rated for 2 conductors.
Geo
Old 07-31-19, 05:08 AM
I
Received 44 Votes on 42 Posts
The lugs are not rated for two wires. Use a wirenut and two short jumpers of wire to split the incoming hot wire to both lugs of the panel. A red or blue wirenut can accept 3 #10 wires.
Old 08-01-19, 12:08 AM
Thanks to all for the support.
Ben, I will pre-wire the panel before installing and post a pic for comments to ensure I have the "split" correct as you described. Thanks again for the assist. Jim
