Wiring a hardwired camera from a receptacle
Old 07-31-19, 07:55 PM
P
I am wanting to install a Ring spotlight camera. On my porch I have a receptacle. How would I extend this to where I could bring the wiring up higher?
Here is what it looks like:
Old 08-01-19, 09:46 AM
P
Received 7 Votes on 7 Posts
The pics don't work for me. Maybe the file size is too large?
Old 08-01-19, 05:14 PM
Received 116 Votes on 107 Posts
That's really an _electrical_ question; but the simple answer is that you pick up the power circuit from that existing receptical, and mount a new one up at the height you desire.
If it was me, I'd eliminate that unused upper box, because the cable coax really isn't supposed to share a conduit with the electrical.
Old 08-01-19, 07:16 PM
Received 1,324 Votes on 1,224 Posts
Photobucket no longer allows third party linking. So you cannot use them for hosting website pictures.
I couldn't tell what's in the top box but it would certainly be easy enough to put a connector in that box and using 1/2" pvc pipe..... extend up to a 4" round weatherproof box and install a single hole blank on the floodlight.
Name:  4 round.JPG
Old 08-02-19, 08:35 AM
P
Is the connector the photo you uploaded or is that the weatherproof box? What kind of wire would I run from the existing reciprocal? Then how would I install it to a single hole? I am new to this type of electrical work. (sorry if it was the wrong section).
Old 08-02-19, 08:16 PM
In general, you simply match the wire already used in the existing.
I've shifted this thread to the electrical forums, so you can get better advise.
Old 08-02-19, 08:26 PM
In the picture is the 4" round box and it's blank cover with a 1/2" hole for the camera/floodlight.
You would use either #14 or #12 THWN/THHN wire. You'd need white, black and green for ground. Many of the home improvement stores have that wire on bulk reels. Sometimes they have cut pieces for just a few pennies. If all else fails.... you could use a short piece of #12 or #14 UF cable thru the pipe although it's a little harder to work with.
You need a piece of 1/2" PVC electrical conduit. Typically it only comes in 10' lengths. You could cut it to get it in your car. In the same aisle.... you'd pickup two 1/2" PVC connectors and a small bottle of PVC glue..
Old 08-03-19, 11:18 AM
P
Thanks. I just don't understand what I am doing with the box.
Old 08-03-19, 01:54 PM
There are several mounting choices for that camera. You can use the power cord which will look.... meh..... or you can attach the camera directly to an electrical box. I didn't know the camera came with the actual 4" mounting plate. The video illustrates what I'm talking about. If you want to plug the camera in.... use a square electrical box with a receptacle and weatherproof in-use cover.
Ring camera mounting
Old 08-05-19, 12:37 PM
P
Thanks! I bought all the material yesterday, including a 90° bend pvc pipe. I will try to do this in the next couple of days. I'll post pics when done..or need additional guidance.
