Electrical panel question
Old 08-05-19, 03:24 PM
H
Hoping someone can help identify what the knob is on the top right of my electrical panel?
Old 08-05-19, 03:51 PM
Received 297 Votes on 255 Posts
Never seen anything like it. Is it attached to the panel? Can you take the front of the panel to reveal how it attaches inside.
Old 08-05-19, 04:55 PM
A
Received 69 Votes on 63 Posts
Welcome. Agree with Joe, don't know, but take the cover off and have a peek inside. Yes, there is voltage in there that can hurt you, but you can remove the four screws at the corners and take the cover straight out with no harm.
Old 08-05-19, 05:16 PM
Geochurchi's Avatar
Received 88 Votes on 83 Posts
Hi, I will bet itís a surge protector for lightening strikes, wipe the top off and see if there is anything written there.
Geo
Old 08-05-19, 06:05 PM
Received 1,336 Votes on 1,234 Posts
Welcome to the forums.
Yep..... that's an older surge protector.
Old 08-05-19, 06:43 PM
H
Thanks to everyone for your responses. Here are two pics. There's two wires coming into the box that go into the two circles in the first pic. If this is a surge protector is it needed or can it be removed. Don't think this is something I would want to try and would need to hire someone? Was looking to frame the box in but this surge protector is in the way.
Old 08-05-19, 07:37 PM
New pictures not showing up for me.
Old 08-05-19, 08:29 PM
The second picture is just a repeat of the picture in your first post. It shows the panel with the suppressor in the upper corner.
In looking at your picture..... it appears the surge protector is connected directly to the mains before the main circuit breaker. That means you'd need to pull the meter to work those terminals dead. As an electrician.... I could remove those wires without pulling the meter. It needs to be done carefully.
