Working with plastic saddle boxes
Old 08-10-19, 04:25 PM
While I am working on my other projects I want to get a small halogen light installed more according to code than it is now. Based on the location of the light I think my only option is a saddle box like this:
Carlon CFB-16
https://www.homedepot.com/p/Carlon-1...B-16/207205361
I am sure I am supposed to use metal, but there are none. Other than that I am assuming I can connect a 1/2" EMT or flex conduit connector, running a ground inside conduit.
Also, is anyone aware of a deeper model?
Old 08-10-19, 04:51 PM
Received 74 Votes on 68 Posts
I do not think you can attach a conduit to that box.
Old 08-10-19, 05:20 PM
I think it does have a knockout. But I shouldn't?
Old 08-10-19, 05:50 PM
I could be wrong. I have not worked with one of those before. It just doesn't appear from the image to have any place to attach a conduit. I suppose you could come in from one side.
Old 08-10-19, 09:34 PM
Received 331 Votes on 309 Posts
Some of those plastic boxes are designed with NM clamps but most have 1/2" ko's.
I'm not a fan of using plastic boxes on EMT. Technically it wouldn't be allowed for two metal conduits but a single grounded metal conduit with an internal ground wire is ok.
What I want to know is how you're going to attach that to conduit without opening the ceiling.
Saddle box with 1/2" KO
Old 08-11-19, 06:35 AM
I think I found another solution.
All I woudl need is a ~ 1 1/4" deep pan box.
I think they make them only either as 1/2" or 1 1/2" deep with 1/2" knock outs?
I think Garvin has 3/4"
However, I could do this to get at least one inch:
1/2" deep pan box extension
https://www.garvinindustries.com/ele...yABEgJzofD_BwE
with
https://www.garvinindustries.com/ele...nd-boxes/46111
or
https://www.garvinindustries.com/ele...nd-boxes/46112
