Reload this Page >
Help to eliminate one 3-way switch and convert other to 2-way
Old 08-14-19, 01:49 PM
Hi.
I replaced the exhaust fan in my bathroom. The new fan is working well with the existing 2 switches (one in the bathroom and one in the hall). But the new fan includes a switch with a timer and a moisture sensor and I would really like to use it. How can I remove the switch in the hall and install the new switch in the bathroom? I have included an imgur link with pictures.
Thanks in advance for any help.
http://imgur.com/gallery/0qwUgLg
Popular Reply
08-14-19, 04:02 PM
joed
joed is offline
Received 77 Votes on 71 Posts
Remove the wires from switch C. The three wires from the top left cable are no longer needed. Remove the black from that cable from the black bundle. They are the cable to the other switch. Cap them off and stuff back into box.
Connect your new timer between the black bundle and red from the lower left cable.
If your timer needs a neutral connect to the bundle of whites.
Old 08-14-19, 02:03 PM
It all depends on how your current three ways are wired. I can't get enough info from the image you posted.
Can you pull both three way out of the box and post images of all the wiring in the boxes.
DougOfWar voted this post useful.
Old 08-14-19, 02:22 PM
Received 344 Votes on 322 Posts
Not sure what happened but those pictures are no longer available.
You can post pictures directly to the board....... How-to-insert-pictures.
Old 08-14-19, 02:23 PM
I updated the Imgur link with 2 pictures of the hallway switch. Is that good or do you need more of the bathroom switch?
Old 08-14-19, 02:33 PM
Imported your pictures and labeled them.
A&B is one switch we'll call A
C&D is the other switch we'll call C.
Which switch do you want to eliminate ?
Old 08-14-19, 02:40 PM
Thanks!
Here are 2 pics of the inside of the box of switch a.
http://imgur.com/gallery/U4I1siP
I would like to eliminate switch C and replace switch A with the new exhaust fan switch.
Old 08-14-19, 04:02 PM
DougOfWar, PJmax voted this post useful.
Old 08-14-19, 04:28 PM
Thank you very much, joed!
So I remove all of the wires from the top left cable that go to switch C? I can wrap them all together with a Marette? And do the same in the box for switch C? Then I'll remove that switch (C)and put a blank cover plate on the box. The new switch also has a green (ground?) wire. What do I do with that?
Old 08-14-19, 04:54 PM
Yes....you can wirenut them together. You can do the same at the switch end that is getting removed. This way in the future you'll know this is the same cable.
There is a black/hot splice, a white/neutral splice and a ground splice. You can connect your new switch to the ground splice. Just look for where the bare wires connect together.
Old 08-15-19, 04:14 PM
Thanks very much to joed and Pjmax!!
It all went very smoothly and the exhaust fan is now operating off of the new switch. And I'm a Home Reno genius that doesn't need to hire a damn electrician! (Please, nobody tell my wife about this forum).
Thanks again for all of your help,
Doug
Old 08-15-19, 04:20 PM
Good job. Name:  thumb.jpg
Size:  1.6 KB You're very welcome. (we won't breath a word to the wife )
