(Should Be) Simple Light Connection...
Old 08-17-19, 08:46 PM
So, I purchased a set of sconces, and lo and behold, I go to install them and...it is something I've never seen before. I imagine this has to be some kind of, ahem, "advancement", but what do I do with this?
Should I just cut it off and go traditional Black to Black and White to White? And what abou the ground?
Thank you for your help...!
Old 08-17-19, 09:34 PM
Received 96 Votes on 88 Posts
Stick the white wire in the hole opposite the white and tighten the screw. Same for the black and the ground
Old 08-17-19, 10:35 PM
That works and is safe? Seems so tenuous of a connection.
Old 08-18-19, 05:28 AM
Norm201's Avatar
Received 93 Votes on 85 Posts
It's called a modular design and is becoming more and more common.
Old 08-18-19, 06:33 AM
Tolyn Ironhand's Avatar
Received 60 Votes on 53 Posts
I have seen many of those fail/melt/burn due to poor connections. I would cut it off and use standard wire nuts. Wire to wire contact is better than any connector like that.
Old 08-18-19, 07:14 AM
Geochurchi's Avatar
Received 19 Votes on 19 Posts
Hi, does that fixture have a UL listing?
Geo
