110v Solenoid valve wiring help
Old 08-19-19, 11:59 AM
B
Hello,
I'm working on a random project for a hobby and need help.
I'm looking to control a 110vac solenoid valve with a foot switch.
Solenoid valve has 2 wires (normally closed)
Treadlite foot switch
Can someone draw up a wiring diagram from 110v power cord to wire up the switch and solenoid valve? It seem pretty simple but may be over thinking it.
Thanks!
Old 08-19-19, 12:04 PM
It is very simple hot power wire connect to foot switch one connection. Other foot switch connection to solenoid valve. Other solenoid valve connection to neutral connection.
Old 08-19-19, 12:31 PM
Received 3,181 Likes on 2,856 Posts
A little visual reference........ Name:  pedal.jpg
Old 08-19-19, 12:51 PM
B
Thanks for the quick replies!
What if I want to add a second pedal and solenoid to this circuit?
Pedal 1 to Solenoid 1
Pedal 2 to Solenoid 2
Old 08-19-19, 01:02 PM
You would just duplicate what is shown.
Old 08-19-19, 03:05 PM
Depends what you want for the second pedal. Do want both need to be pushed for the valve or do you want each one to operate the valve separately.
