How to increase spade connector size
Received 0 Votes
Hello,
I am replacing an element in my oven where it uses spade connectors to make the connection. The spade connector on one of the terminals is of a different size.
I don't have the length to cut the wire and replace it with the right size one it seems. Is there an adapter or something one can get to go from small to large?
I have done some googling but haven't found anything that I would imagine does this.
Thanks for the assistance.
Received 0 Votes
Maybe one other question related. I have checked all over town for this and can't find it so am thinking to order it via the link you provided.
How do i know which to get however? Is it as simply as taking a tap measure to it? Also, since this for a stove top element i assume it gets pretty hot. Will these work for this?
The size is 1/4". My concern is the wire or that extension terminal hitting the back cover of the oven.
There should only be a few screws holding the back cover on. Check for spare wire first.
