gfi outlets in kicthen
Old 08-21-19, 06:23 PM
Question gfi outlets in kicthen
There was two gfis on the same circuit , but the second on was the load side of the first one. Should they be like that ? Our should be pig tail on the load side Being like that does one effect the other when something is plug in .
Old 08-21-19, 06:29 PM
pcboss's Avatar
Received 40 Votes on 35 Posts
There is no need for the second gfi to be wired from the load side of the first gfi. Just switch the wires to the line side of both and the gfi function will not affect the other
CasualJoe voted this post useful.
Old 08-21-19, 10:35 PM
Received 136 Votes on 122 Posts
It is perfectly fine the one receptacle on the LOAD side of the first. It save the expense of buying two GFCI receptacles.
