Reload this Page >
what if cable not long enough when using junction box to split electrical line?
Old 08-24-19, 10:23 AM
Received 1 Vote on 1 Post
I have added two pendant lights to a kitchen area. I have the two lights wired to work off a single switch. But, I don't yet have power going into the switch for these lights. I need to splice into an existing electrical line in the attic. I presume I will be using a junction box for this. The problem I see arising is that none of the existing lines in the attic have much slack to allow me to have adequate length to cut a line, runs the ends into the box, and split the incoming line into two outgoing lines. If I'm correct in thinking I'll need more length to work with, how do I obtain/create that extra length?
Old 08-24-19, 11:03 AM
Received 75 Votes on 69 Posts
You need two boxes. Bring the two ends into each and add piece between.
Old 08-24-19, 12:59 PM
OK, thanks. I just bought another box. So, I now have two boxes to work with.
Old 08-24-19, 05:28 PM
pugsl's Avatar
Received 19 Votes on 18 Posts
Be sure to put blank covers over splice boxes.
Old 08-24-19, 06:07 PM
Hi pugsl. When I went to the hardware today to buy another box, this issue (of a cover) was raised by a guy working there. He asked whether I wanted/needed a cover for the box. Since the attic has blown-in insulation covering everything, the answer to his question was easy. I mentioned the insulation to him and said I wanted a cover to keep insulation out of the box.
Old 08-25-19, 04:29 AM
pugsl's Avatar
Also cover required by code...............
