What to do about Old Wiring
Old 08-24-19, 03:32 PM
Exclamation What to do about Old Wiring
I was just going to change a Chandelier at my daughter's house and found this. It is cloth wiring? Whatever it is, it falls apart just from moving it. The switch is off to the lighting wires but there is also a junction in the box which I believe is still hot. The wires aren't copper and appear to be metal or aluminum(?) and both have black casing. I just need to know how to safely connect this or should I just have her call an electrician? There is no access to the top since it is on the first floor and the house is a Cape Cod built in the 1940's.
Old 08-24-19, 03:50 PM
Received 14 Votes on 13 Posts
that is cloth wrapping over rubber insulation.
You can fix insulation with electrical tape or heat shrink tubing (better option). Wires outside of the junction box will be fine so long as they are not disturbed.
Conductor on this type of wire will be tinned copper.
Old 08-24-19, 04:00 PM
That brings me to the next question. The new light will have a black and a white wire. Will it matter which one I connect to since the supply wires in the box are both black?
Old 08-24-19, 04:58 PM
It does matter for safety reasons. You will have to figure out which is neutral (white) and which is hot (black).
Since you have a cable feeding another junction box, you will find a bundle what was not tied to old light. This is your hot line feeding another junction box. Do not disturb is unless you see damaged insulation. If you disturb it, you may damage the insulation.
A bundle that was attached to old light will be your neutral. (connects to white wire)
A single wire that was attached to old light will be your switched hot. (connects to black wire)
If you don't remember which is which, easiest way is with non-contact tester, although some disapproves use of them.
Put your non-contact tester on the wire in question with switch on and off. The wire that beeps with switch on and doesn't with switch off will be your switched hot.
A bundle that shows hot all the time will be hot line feeding another junction box and the remaining bundle will be neutral.
Old 08-24-19, 05:39 PM
Geochurchi's Avatar
Received 15 Votes on 15 Posts
Hi, I would definitely use heat shrink on those conductors, trying to tape may do more damage, if you have a meter test between the box and a conductor, the one that goes off/on with switch is the black .
Geo
Old 08-24-19, 05:55 PM
That is some great information. Thanks. It didn't help that both wires from the old light were brown.
Old 08-24-19, 06:45 PM
Considering the age of wiring, it may not be grounded. Probably old BX cable without bonding wire.
Metal cladding may provide some ground, but cannot guaranty if there is no bonding wire. I learned this hard way when I have replacing a light fixture in one of these.. Mounting screw nicked insulation on hot wire and caused short to box. Instead of tripping the breaker, the wire and screw got glowing hot then melted off. I was lucky that it did not burn entire wire off.
Poor grounding may be worse than no grounding.
Old 08-25-19, 03:47 PM
Thumbs down Bad to Worse
This wiring is just too deteriorated for me to work with and we are calling an Electrician. The Neutral has no insulation left and the live connection (with red wire nut) show signs of exposed areas on the wires. The heat shrinking as some suggested would have worked but I think it would instantly destroy whatever is left of that cloth wrap since it is so brittle. There is no access to the top of the box from above, so I would think they'd have to pull the box down and try to find some good connections up top in order to run some new wire into the box. Any suggestions at this point would be great since I think we're out of options as far as DIY.
Old 08-25-19, 04:59 PM
Received 17 Votes on 16 Posts
Running a new cable to an overhead light isn't the easiest project, but with a couple small holes in the wall/ceiling, it's not a hard project. That's probably the best solution, to run a new cable from the switch to the ceiling box. And possibly from the light switch to the basement to clean up the whole setup.
It'll require a bit of drywall work afterwards, but having a nice clean new run is definitely the safest/best solution!
Old 08-25-19, 06:41 PM
If that cable is non grounded as I think it is, you have to replace entire circuit as you are not allowed to extend ungrounded circuit.
The electrician may consider metal cladding a good ground, but if it is not bonded, you may have issue I explained in earlier post.
If you have a plaster ceiling as wall, then it may become much bigger project.
You can just remove remaining insulation off the wire and push heat shrink tubing as far as you can (Ideally into the metal cladding) and put some heat to shrink the tubing.
Old 08-26-19, 02:29 PM
The wiring is not grounded. They just ran the ground wire from the old fixture up to the mounting bracket and screwed it on.
Old 08-26-19, 05:00 PM
Received 256 Votes on 241 Posts
I feel for you there. That is in bad shape and almost impossible to fix without access from above. I recently did a job with 6 old cloth covered BX's into one acorn box like you have there. If I didn't have access from above.... there would have been some major rewiring needed.
You can cut back to get to better insulation but it will still crumble. Those wires are baked from years of heat from a light fixture below.
Old 08-28-19, 05:21 PM
I'm not desperate yet, but what if I loosened the clamps and just tried to pull down some better wire to work with. It all depends if left any slack in the wiring but it might be worth a shot.
Old 08-29-19, 05:18 AM
Received 42 Votes on 40 Posts
You could try, but don't get your hopes up. Any flex and disturbance will probably crumble the insulation. Wire of that age used natural rubber and an organic fibers like cotton or flax in the insulation. Once it dries out and deteriorates, it rots away and is just gone.
As Pete said, when you come across a job like this you know it's just going be chasing back and replacing wire runs until you find something good or hit the panel box.
Old 08-30-19, 09:59 AM
Don't be too scared. I've done a few full-house-rewires recently upgrading from knob and tube wiring, and it's not as disastrous as it might first seem to pull new wiring in existing walls. It's not always easy, but it's always doable.
There's often a closet that a small hole can be made to help pull the new wires without creating a lot of holes in your dining room walls/ceiling.
