more outlets
more outlets
have a 24x24 pole barn....have a 100amp box that has 2 breakers in it....a 15 amp for lights and a 20amp for outlets. right now I have 4 outlets in pole barn....1 on north side...2 on south side and 1 on west side. Have a small work shop on south side and storage on north side. The outlet on west side is used to charge battery tools. When working I will have a table saw and vacuum running at same time...other than that everything runs individual. Would like to add some more outlets in different places on the workshop side. could I add a couple on existing circuit...since I don't use the other 2 all that much...right now they are used for battery charging.
I would run a new separate circuit for the table saw. Assuming a shopvac type vacuum that can run on the existing circuit with no problem. All receptacles in the barn should have GFCI protection.
Code in most areas in NA is 12 outlet/lights per circuit. I wouldn't run two saws at the same time, but 20A should be ok if its just yourself using stuff.
