Power to shed
Old 08-30-19, 07:25 AM
Power to shed
Thank you in advance to all who may be able to help. I really appreciate it. I would like to run power to a backyard shed for some general purpose lighting and a few receptacles. T he shed is located approximately 115 feet from the main house panel. I don't anticipate any future need for a subpanel at the shed so my plan was to install a single 20 amp circuit or 2 circuits using a shared neutral. My questions are: Is # 12 wire sufficient for the 115 ft. run back to the house panel or is #10 more appropriate? Also if I use the shared neutral system am I more likely to experience GFCI trips in the shed receptacles? Again thanks so much for your help.
Old 08-30-19, 09:12 AM
Received 84 Votes on 77 Posts
It should be based on the loads you specified.
Shared neutral will not increase GFCI trips.
Old 08-30-19, 02:18 PM
Thanks joed. I appreciate your help.
