Wire insulation damge: when to be concerned?
During pulling in wire into a 90 degree elbow like this:
https://www.homedepot.com/p/Halex-3-...4407/100111131
I noticed that a 6 AWG stranded wire outer skin was slightly damaged. It append when when squeezing in the loop into place. I t almost seems that there is an outer foil layer and inner insulation. It seems the outer foil only got damaged. I can put electrical tape around it for extra protection. Or redo the pull.....
Just wondering if I should be concerned or not?
P.S. Did not expect inside of elbow be that sharp. Meanwhile, I put FMC Anti-Short Bushings inside.
Don't know all the circumstances involved here, but I would replace the wire because there is no way to determine the degradation of the insulation. Maybe the damaged portion can be cut out and the remaining piece used elsewhere.
well, the outer layer it is not clear. It is black.
I could remove the damaged outer layer and see if it cut into the inner insulation.
But sounds like more than likely I am ok.
My other phase did not get damaged. My ground a little bit. But I don't think I should be concerned about ground in EMT.
