Electrical box set behind sheetrock
Old 09-04-19, 11:02 PM
Hi folks,
Iím replacing the outlets and switches in our playroom. The existing switches are pretty old. On one wall in particular, two of the electrical boxes are set back from the sheetrock. In other words, the front of the electrical box is behind the sheetrock (see attached pictures). So a good portion of the outlet is NOT in the box. I thought that was the whole point of the box, which is to house the outlet in case there were sparks or anything?
So, assuming this is a problem, how should I proceed? I could rip out the old box, but itís nailed to the stud. Any other thoughts? See pics attached.
thanks!
Old 09-04-19, 11:51 PM
Received 50 Votes on 47 Posts
If a box extender does not solve the problem, you cut the nails with a saw and install an old work box.
Old 09-05-19, 05:56 AM
Received 18 Votes on 17 Posts
There are multiple products available for solving your issue.
If your box is just slightly deeper you can use this.
https://www.homedepot.com/p/Ideal-Sp...2453/202937113
If terminals are completely exposed at correct depth,
https://www.homedepot.com/p/Steel-Ci...-25R/202591768
https://www.homedepot.com/p/Electric...E1-2/202708650
or
https://www.homedepot.com/p/ReceptXt...0003/100175417
This type is available in 3/8" , 1/4" , 1/2" and 3/4".
Old 09-05-19, 01:57 PM
Thanks guys, you rock! The metal one that you linked appears to be adjustable, while the plastic ones do not. Maybe Iíll buy all of them and see which one works best.
In the original pictures I posted, the second picture that has the black outlet looks like it will be fine with a typical extender.
The outlet in that first picture has a bit of a strange electrical box because the opening for the outlet is not the perimeter of the metal box, it is set in maybe a quarter of an inch. Hopefully that makes sense.
Old 09-05-19, 09:39 PM
Received 379 Votes on 356 Posts
The first box is a 4" square (1900) box with a mud ring on it. This type of box allowed for extra room for wiring. The mud rings are available from 1/2" to over an 1" but can't be changed after the sheetrock. Box extenders don't work well in those boxes.
Old 09-05-19, 09:53 PM
Thanks, any thoughts on what to do with that first box then? Maybe cut it out with a Dremel?
Old 09-06-19, 07:46 PM
If one of those short spacers are too big then you'll have no choice but to use one of the plastic extenders. That would be some pretty tough metal to cut out.
Old 09-07-19, 06:30 AM
Extension ring will work fine with that box.
Old 09-07-19, 11:14 AM
OK, after about 2 1/2 hours I finally finished the first outlet in my original post. I wound up having to cut the sheet rock a little bit to fit the box Extender, used the largest extender, as well as a few spacers, and eventually got it. Thanks for the help. Two pictures below of the finished product.
Now I am on the second outlet, which is a little different. The box extender fits around the electrical box pretty easily, but there is a bit of a gap at the bottom. See attached picture for gap between the electrical box and the blue box extender. Should I be concerned about this gap, or does it not really matter? I see that the box extender works well to make the outlet sit flush with the sheet rock, but in theory it kind of makes a gap as pictured.
Old 09-08-19, 07:15 AM
pcboss's Avatar
Received 31 Votes on 27 Posts
Turn the extender around or use an Arlington BE1.
Old 09-08-19, 10:49 AM
Received 17 Votes on 16 Posts
If the box is set back by 9/16" or more the following metal ring spacer works well:
https://www.garvinindustries.com/covers-and-device-rings/4-square-covers-device-rings/one-gang-device-ring-extenders/dex-150
Old 09-08-19, 11:59 AM
pcboss's Avatar
These are the ones I use. No metal near the screws.
http://www.aimedia.co/media/catalog-pages/S-4.pdf
Old 09-08-19, 02:26 PM
pcboss said...
Please tell me thatís a trade secret to turn the box around and that I didnít just install it backwards lol!
Old 10-05-19, 10:47 AM
Received 1 Vote on 1 Post
I have similar issues with many electric boxes. Can a plastic box extender be used to extend a metal box?
