Multiple RC840T's on a single thermostat
Old 09-09-19, 11:47 AM
I have 3 wall heaters that I'm trying to control using a single Honeywell RTH2300 thermostat. I have 1 RC8402-240 and 2 RC840T-120. If I wire just one (any one) of the heaters up, it works fine. But it doesn't work if I connect all 3. I believe this because all 3 of the RC840T's are trying to drive 24V to the thermostat. I believe it's possible to have just one RC840T provide the power to the thermostat and still signal the other 2 units. In fact there's another thread on this forum that discusses that. Unfortunately the link that was provided in that thread is no longer active. That thread is https://www.doityourself.com/forum/e...ighlight=rc840
and in there the very last comment says that what I want to do is possible. I can replace 2 of the 840T's with 840's if necessary.
I'm thinking to connect the R wire of the thermostat to just one of units; connect the W wire on the thermostat to all 3, and then connect the 3 C wires on the 3 RC840T units together but not wire them to the thermostat.
I'd very much appreciate any guidance or pointers to wiring diagrams that show me what to do. Thanks!
Old 09-09-19, 12:13 PM
Received 517 Votes on 487 Posts
Welcome to the forums.
The problem is anytime you connect transformers together you run into problems. You are proposing connecting the three C connections together. That may or may not work.
I would use a double pole relay. There are two sets of contacts. Based on the diagram below you would connect the coil to the primary unit. You would connect terminal 1 and 3 to the second transformer unit on the W and R terminals. You would connect 4 and 6 to the third transformer unit. This way you could keep what you have and they would be isolated from each other.
Double Pole relay
Old 09-09-19, 01:21 PM
Thanks Pete. That's very helpful. Please clarify the part where you say "you would connect the coil to the primary unit". I assume I connect the R and W wires of the primary to the thermostat; do I use the same wires to drive the coil?
Old 09-09-19, 01:24 PM
You would connect the coil to W and C on the first unit.
Old 09-11-19, 04:35 PM
Thanks Pete. I bought and wired up the relay you specified but I'm still having a problem.
I confirmed that the wiring to the 2 remote units is correct (when I connect one remote unit to contacts 1 and 2 that unit turns on, and when I connect the other remote unit to contacts 4 and 5 the other unit turns on. I then connected them correctly to 1 and 3, and to 4 and 6 so that they are off by default).
The problem is with relay activation. I connected the coil on the external double pole relay to the C and W wires of the RC840T. When the RC840T is turned on by the thermostat (red light comes on on the RC840T), a loud buzzing comes from the relay (I think) and none of the units turn on. If I disconnect either the W or C wire from the relay, the buzzing stops and the directly connected unit turns on. I've used a voltmeter to confirm that there is 24VAC between them W and C when the unit is turned on and one of the wires is unplugged from the relay. Is it possible that the current draw for the 2 relays is more than the RC840T can provide and so neither the internal relay nor the external double-pole relay is turning on? Is there a way to address this?
Old 09-11-19, 04:43 PM
Check the AC voltage to the external relay when it's active.
Since you're using a battery operated stat...... the main 840 should be able to run the aux relay.
Old 09-11-19, 06:35 PM
It drops to 11VAC when it's connected to the relay. It jumps back up to 24VAC if I disconnect either wire from the relay.
Old 09-11-19, 10:21 PM
Wow..... they've really reduced the size of the transformer in those units. That relay draws minimal power.
I'm not sure what to offer. I have connected relays to them in the past with no problem.
Old 09-12-19, 06:39 AM
Geochurchi's Avatar
Received 25 Votes on 24 Posts
Hi, the output rating on the RC 840 is listed at 40ma. what is the rating on the relay?
Your sure the coil voltage is 24VAC.
Geo
Old 09-12-19, 09:46 AM
Here are the specs on the coil for the relay. If this requires more power than the 840T can provide, is there an alternative part I could buy instead? Or is there a way to use an external 24V transformer and give up on using the 24V from the 840T?
Specifications
Coil Voltage24 Vac, 50/60 HzTerminals 1-2-3PowerTerminals 4-5-6PowerCoil Data17.5 D.C. Res., 334 mA, 9.5 Nominal VA, 22 Inrush VACoils, Operate85% of nominal coil voltage; 110% maximum safe operateCoils, Duty CycleContinuousApprovalsU.L. file number E12139C.S.A. file number LR13360Coils, Operate85% of nominal coil voltage; 110% maximum safe operateCoils, Duty CycleContinuousAgencyU.L. file number E12139C.S.A. file number LR13360
Old 09-12-19, 09:51 AM
Sorry -the formatting got screwed up. Hopefully it's still legible but trying again
Coil Voltage 24 Vac, 50/60 Hz
Coil Data 17.5 D.C. Res., 334 mA, 9.5 Nominal VA, 22 Inrush VA
Old 09-12-19, 02:23 PM
I have it working. I decided to buy an external 24V transformer and use that instead. In case anyone else has the same issue, I followed the 2-wire wiring instructions from this page:
https://www.warmlyyours.com/en-US/pu...ON-GUIDE-A.pdf
Thank you both for all of your help.
Old 09-12-19, 02:49 PM
Good job. Name:  thumb.jpg
Size:  1.6 KB That relay I had you use must be slightly higher draw than the straight 840 relay.
