changing condenser breaker fro 60 to 30 amp
Received 0 Votes
condenser label requires 30 amp breaker, but mine is 60 amp. Electrician said just to change the breaker on the service panel which i think will be from 40 to 30 amp. Is that correct/
Welcome to the forums.
Your breaker is 60A but you'll be changing from a 40A to a 30A.
I think something got lost in the translation.
Many times a larger service than needed is run to an A/C condenser or it was a heat pump system with electric heat and was needed at one time. You can change the breaker in the main panel that supplies it to a 30A or you may have a fused disconnect at the condenser where you could change to 30A fuses.
