afci circuit breaker
Old 09-10-19, 04:22 PM
I replaced a 15 amp circuit breaker with a 15 amp afci circuit breaker that controls the ceiling lights and is controlled by two switches. I flipped the breaker on and it immediately tripped out. I removed all the light bulbs from the circuit and the new breaker didn't trip. As soon as I put one light bulb in its socket the breaker trips. I had no problem with the standard breaker before. Why is this. Thank you. James
Old 09-10-19, 04:37 PM
Received 74 Votes on 68 Posts
Possible ground neutral interconnection.
Does it trip with the bulb just installed or does it need to be on for the trip to occur?
Old 09-10-19, 04:42 PM
Received 21 Votes on 17 Posts
Does the afci breaker you have also provide ground fault protection?
See this... https://www.jadelearning.com/combina...rcuit-breaker/
Astuff voted this post useful.
Old 09-10-19, 04:44 PM
I flip the afci breaker on with no load. Then I put in its socket ne light bulb
Old 09-10-19, 04:52 PM
The afci breaker is in on position. I put one light bulb in its socket and when i turn the switch on the breaker trips
Old 09-10-19, 04:57 PM
No it is only a 15 amp afci circuit breaker
Old 09-10-19, 05:40 PM
Received 6 Votes on 6 Posts
Describe the light bulb. If not incandescent, try one.
Old 09-11-19, 03:15 PM
Tolyn Ironhand's Avatar
Received 54 Votes on 47 Posts
The circuit might be part of a multi-wire circuit which will not work on a single pole AFCI.
