Several electricity outputs to one
Old 09-12-19, 02:17 AM
Hey,
If I want to connect several electricity outputs to eachother, meaning for example 2 electricity, 2 USB, 1 QI wireless charger and 1 USB-C, what do I need to do that?
The requirement is that there should only be one cable going from this device to the electricity plug in the wall.
Thank you!
Old 09-12-19, 03:51 AM
Received 28 Votes on 24 Posts
Check the Qi wireless charging standard from the Wireless Power Consortium (WPC) for your solution.
Old 09-16-19, 01:02 AM
Hey,
What specifics should I check at WPC for the specific QI charger?
Old 09-17-19, 06:15 PM
Provide a list of all the items you want to connect including manufacturer, model number and their required input voltage and current.
Old 09-18-19, 09:51 AM
Received 19 Votes on 18 Posts
The easiest solution is to use a power strip, or multi-outlet extension cord. No wiring (or loose connections) to worry about, everything just plugs into the cord
I'd pick something like this (there are hundreds of similar options)
https://www.amazon.com/Desktop-Outle.../dp/B07HCVFH82
Mount the power strip in whatever box you're building.
