Running SER unsheathed in a finished space
Old 09-14-19, 02:10 PM
Hi all,
Just wondering if SER must be sheathed all the way into the panel. I'm rewiring my currently as I'm refinishing my basement. Installing a new main panel in the basement. I will be installing a 200A service disconnect/ meter socket at the drop. I know I must run conduit to the point of entry, which will be a crawl space.
As the main will be technically a sub, I'm running 4/0,4/0,4/0,2/0 SER from the disconnect. The new panel will be in a finished space. But to get into the panel, a tight bend need to happen behind a joist. Can SER be unsheathed and out of conduit indoors, if in a finished space?
Thanks in advance
Old 09-14-19, 02:17 PM
Picture for clarity, can the SER be unsheathed at the joist, prior to the penetration to drop into the panel?
Old 09-14-19, 02:26 PM
Tolyn Ironhand's Avatar
Received 54 Votes on 47 Posts
No. A jacketed cable is required to have the overall jacket the entire length, including if it is run in conduit. The only place the jacket can be removed is inside an enclosure/box.
To make the bend you will have to drill a good-sized hole.
Gingeriffik voted this post useful.
Old 09-14-19, 03:03 PM
Thanks! That's what I was wondering.
Can it be ran all the way (in finished space) without conduit (jacket intact)?
Old 09-14-19, 04:01 PM
Yes, SER is rated to be run indoors through joist and stud spaces.
Old 09-14-19, 06:23 PM
Thanks again! Really appreciate the clarification.
Old 09-15-19, 07:01 PM
Received 343 Votes on 321 Posts
You will need large holes to run that cable thru joists.
It is recommended to use nail plates anywhere a screw could catch that cable.
