Not as easy as it looks for a novice
Old 09-14-19, 03:06 PM
Dad always said, if you don't know, ask. Please take a look and give your opinion.
Old 09-14-19, 04:11 PM
Tolyn Ironhand's Avatar
Received 54 Votes on 47 Posts
The first main breaker is the only place the ground and neutrals are connected together. Everything after that is a sub panel and needs 4 conductors run in the feeder.
I would install ground rods at the main panel and the disconnect panel of the mobile home. The panel inside the mobile home I would not install a rod as you should be able to connect to the same rod as the disconnect.
carolina jim voted this post useful.
Old 09-14-19, 04:54 PM
Thank you so much! That will solve my situation. Now maybe we can move in. This has been a 10 year project with all the different things that needed doing.
Old 09-15-19, 05:59 AM
Received 6 Votes on 6 Posts
You have 6 breakers feeding 6 breakers?
something missing in the diagram?
Old 09-15-19, 11:58 AM
The first main used to supply original home. Using same box w/o moving pole. Just running new triplex to a pedestal for a junction instead of splicing. Wire wasn't long enough.Can also suppl A/C unit and air comp. as a sub panel. New mobile home is the last sub panel.
All are 200 amp mains.
Old 09-15-19, 01:10 PM
As mentioned, you need 4 conductors so you need to use quadplex.
Old 09-15-19, 01:19 PM
Triplex with #6 copper strand. Is that O.K?. My brother is a lineman for the local power company and supplied the triplex and I bought it from the utility..He sometimes needs to be checked up behind him. He has me bonded in the pedestal.
Old 09-15-19, 01:22 PM
Yes.
