1000 watt output 120volts and 15 amp circuit
Old 09-22-19, 10:41 AM
Lifesmart LS-IF1500DUFP space heater
Old 09-22-19, 10:45 AM
Received 337 Votes on 315 Posts
Welcome to the forums.
What would your question be ?
That Lifesmart heater is 1500 watts which is 12.5 amps at 120v.
It would be ok on a 15A circuit but much better on a 20A circuit.
ampdummy123 voted this post useful.
Old 09-22-19, 10:49 AM
can one operate a small fireplace heater with a 1000 watt output from an outlet with a 15 amp circuit without overloading?
Old 09-22-19, 10:51 AM
I added to my post while you were replying. That looks like a 5100 btu heater which is 1500 watts.
Old 09-22-19, 01:14 PM
Received 74 Votes on 68 Posts
It will be fine by itself. If you start adding other loads to the circuit then it depends on what the other loads are.
Old 09-23-19, 07:54 AM
It has 2 settings, 1000 watt and 1500 watt. I intend to use only 1000 watt. If I switch on light bulbs at the same time that should not trip the circuit?
Old 09-23-19, 08:08 AM
Received 15 Votes on 15 Posts
Yes you can have some lights on at the same time as the heater drawing 1000 watts.
The 15 amp circuit will allow 1800 watts usage without tripping. But for heaters and air conditioners and other appliances likely to be left on for a long time like 3 plus hours they should not be drawing more than 80%, here, 1440 watts, okay you could round it to 1500 watts..
