Correct wire size?
Old 09-22-19, 12:23 PM
Question Correct wire size?
I will be installing a new CNC spindle soon in my basement, and those that have used this type of spindle before have told me that a 20 amp circuit is not going to be big enough. They said to install a 25 amp circuit.
The cable run will be around 30 - 40 feet long. Should I use 8 gauge wire, 30 amp wall outlet, and a 25 amp circuit breaker?
Old 09-22-19, 01:04 PM
Received 479 Votes on 449 Posts
#10 is rated for 30A and would be fine here. If you can't find a 25A then you'll need to use a 30A.
