Reload this Page >
trying to replace a light switch with motion sensitive switch
Old 12-14-19, 11:51 PM
replacing a light switch with a motion sensor
I am trying to replace a light switch with a motion-sensor switch. The current switch is lighted (i.e. it has a tiny light to help locate the switch in the dark).
Below is a picture of the current connections. It has 2 black wires and a ground wire. There is also a bunch of white wires tucked in but not connected to the switch (2nd picture).
Old 12-15-19, 04:46 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi, should be no problem, what type of sensor are you using?
Geo
Old 12-15-19, 05:30 AM
Norm201's Avatar
Received 677 Upvotes on 600 Posts
So what's your question? What don't you know how to connect?
The black wire is your power source. A switch (any switch) will open or close that power.
Post a pic of your new switch.
Old 12-15-19, 09:15 AM
Here is the link to the product:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Is there any way to guess which wire would be neutral? I have found that wires in my place are not properly color-coded.
Old 12-15-19, 09:40 AM
pcboss's Avatar
Received 168 Upvotes on 147 Posts
You do not have a neutral at the three way switch.
the single pole switch has a group of neutrals not connected to the switch.
Old 12-15-19, 10:33 AM
Received 3,485 Upvotes on 3,128 Posts
You have a single pole switch with two black wires. With the switch turned off you need to measure for voltage on either one. The wire that has 120v on it is the LINE or HOT. The wire that has nothing on it is LOAD or LIGHT.
The white wire from the switch goes to the three white wire splice.
mrdoc voted this post useful.
Old 12-25-19, 10:04 PM
Installed successfully.
Thanks
