Subpanel
Old 09-24-19, 12:17 PM
Subpanel
Why can I only get half the panel to work. I fed it from my house panel to my shed using #4 wire about 45 but only every other breaker is working
Old 09-24-19, 12:42 PM
Received 84 Votes on 77 Posts
Not enough info to answer your question.
Did you use a four wire feed?
Did you use a double pole breaker in the main panel?
How did you connect it at both ends?
Old 09-24-19, 01:26 PM
Received 31 Votes on 30 Posts
Is the panel 240 volt.
Sounds like you are missing half the line.
