switch/receptacle wiring
i am trying how to connect wiring for a combo switch/receptacle. Anyone tell me connection of wiring to it?
Thanks
Thanks
How many wires are there in this box to work with. If you answer "two, one black and one white", then I'm going to tell you that this job is impossible -- there is no way to wire it. If you answer "four, two black and two white" (or any other answer), then we'll provide further information based on your answer.
As John said under the current existing wiring it can't be done, if only 2 wires at the switch location, the source of power is at the the fixture and there is no neutral wire at the switch location.
You need an unswitched source for of power / hot & neutral.
