Reload this Page >
Installing additional receptacle/box in garage ceiling for garage door opener
Old 09-26-19, 06:03 PM
I am going to install a direct drive garage door opener which requires an electrical outlet nearby.
Just wondering if there are any requirements in terms of size of retrofit electrical box for a duplex or single receptacle.
Old 09-26-19, 06:36 PM
Received 87 Votes on 80 Posts
Nothing special. Just install a junction box and a duplex receptacle.
New code requires it to be GFCI protected.
Old 09-27-19, 06:13 AM
Something like this woudl be ok?
https://www.garvinindustries.com/ele...oxes/g600-owbx
Old 09-27-19, 07:34 AM
Tolyn Ironhand's Avatar
Received 59 Votes on 52 Posts
Something like this would be ok?
That is fine, but if you are using NM cable (Romex) then I would recommend using a plastic remodel box.
https://www.homedepot.com/p/Carlon-1...-202077323-_-N
Msradell voted this post useful.
Old 09-27-19, 12:06 PM
I am in conduit land. So, I am planning on using flex conduit.
It looks like boxes are available form 2" to 3 1/2" depth in 1/4" increments.What is the most common depth used?
Old 09-27-19, 12:16 PM
Received 11 Votes on 11 Posts
gfi installer will appreciate a deeper box.
Old 09-27-19, 01:27 PM
Received 3 Votes on 2 Posts
The code "gotcha" is that the GFCI device must be readily accessible (no ladder required).
Old 09-27-19, 02:00 PM
That would be an issue. Is this an accepted alternative?
https://www.homedepot.com/p/Siemens-...115P/100094053
Didn't even know it exists....
Old 09-27-19, 02:36 PM
Yes breaker is an acceptable solution. So is installing a GFCI in the receptacle that feeds this one.
Old 09-29-19, 11:07 AM
As a result I will have GFCI protected outlets in my garage fed by this GFCI circuit breaker. I know we don't install GFCI into GFCI. On the other hand I don't see any harm. What woudl an inspector say?
P.S. Since GFCI circuit breaker do exist, why wouldn't the trade simply switch to use those vs. GFCI outlets?
Old 09-29-19, 11:14 AM
1. It is much easier to just press reset on the receptacle you are using than to go find the panel and press reset.
2. Receptacles are cheaper than breakers.
Old 09-29-19, 01:17 PM
Personally I would change out the redundant GFCI receptacles. No harm (other than wasting a tiny bit of power), just confusing. Perhaps you can find a use for them elsewhere in the house (if you test all the GFCIs, you might find some that no longer function).
Old 09-29-19, 03:02 PM
Please elaborate. Are saying GFCI uses power when nothing is plugged in?
Old 09-29-19, 03:13 PM
Yes, GFCIs contain electronics which are always powered.
