Switch to Switch/Outlet Combo
Old 09-29-19, 01:25 PM
Hello all! I'm new to the forum and would really appreciate all the help I could get.
I noticed this is a pretty popular topic but wasn't able to find an answer to my situation.
I'm trying to replace a switch with a switch/outlet combo, but it appears there is no ground wire in the wall. There are the black and white wires as expected, and an inaccessible red wire in the back. But no sight of green/copper wire.
Would it be possible/safe to attach the new combo in the situation?
Thank you all for your time and help!
Last edited by PJmax; 09-29-19 at 02:52 PM. Reason: reoriented/resized/labeled pictures
Old 09-29-19, 02:29 PM
pcboss's Avatar
Received 31 Votes on 27 Posts
Where are you located? If the wiring method is a complete metallic conduit it is the ground.
Old 09-29-19, 02:52 PM
@Pcboss,
Thank you for the tip! I figured it out only to realize i'm short a hot wire+ neutral line to get the outlet to work. To the hardware store!
@PJmax,
Thanks for labeling the photos!!!
