Quick question
Old 10-06-19, 11:00 AM
P
Quick question
I have a switch that control 3 lights on the way down to the basement AND another 2 lights that r in a storage area i rarely use. Could i just cut the wire after the first 3 lights and install another switch to control the 2 lights in storage area? Is it that simple? I understand that the switch for the first 3 lights would have to be on in order for the new switch to actually turn on the 2 storage room lights. Thanks in advance Paul
Old 10-06-19, 11:11 AM
Received 249 Votes on 219 Posts
Yes adding a switch will work.
Old 10-07-19, 09:11 AM
P
Follow Up
ok so u cut the wire but not sure how to attach the switch. The switch only has 2 side terminals and I now have 2 blacks and 2 whites. How does that work. Thanks in advance yet again. Paul
Old 10-07-19, 09:47 AM
O
Received 1 Vote on 1 Post
Connect the two black wires to the two terminals on the switch and connect the two white wires to themselves using a wire connector.
Old 10-07-19, 09:53 AM
Received 157 Votes on 144 Posts
Whites get tied together with a murret.
Then a black to each side of the switch.
