2 GFI'S IN A BOX
I AM WIRING MY POOL FILTER. I WANT TO FEED THE FILTER THROUGH A TIMER BY THE PANEL AND THE REQUIRED OUTSIDE OUTLET WITH CONSTANT POWER.
MY SOLUTION IS TO FEED TWO GFI'S ON TWO DIFFERENT CIRCUITS IN A TWO GANG BOX THAT WILL BE LOCATED ON MY LAWN. ONE GFI WILL BE FEED FROM THE TIMER AND ONE WILL BE FEED FROM THE PANEL.
SO THE QUESTION- DOES EACH GFI REQUIRE IT'S OWN NEUTRAL AND GROUND? OR CAN I RUN ANOTHER HOT WIRE THROUGH THE CONDUIT AND SHARE THE NEUTRAL AND GROUND WITH A PIGTAIL?
Thanks
Thanks
Each GFCI circuit will have to have it's own neutral run with the ungrounded circuit. As for the equipment grounding wire, you can share this.
Good luck.
Rick Miell
PS. When you type a question in all caps, it looks like your shouting. Take it easy on use out here and lower your voice.
Good luck.
Rick Miell
