Wiring smoke detectors?
Old 10-18-19, 07:34 AM
I have 6 smoke detectors and 1 smoke/CO detector, all wired together. I want to disconnect one smoke detector from the network. Presumably I can do that by just not connecting the yellow wire.
But will the rest of the network still work normally; and the disconnected unit still work normally, just not being part of the network (ie. it will go off, but not set the rest off, and not be turned on if another one goes on...)?
Old 10-18-19, 08:11 AM
Received 23 Votes on 19 Posts
Correct. They will work as you are thinking.
Old 10-18-19, 08:45 AM
Geochurchi's Avatar
Received 17 Votes on 17 Posts
Hi, what type of SDs are you dealing with?
Geo
Old 10-18-19, 11:38 AM
BRK First Alert 7010B and SC7010B
Old 10-18-19, 11:47 AM
Received 370 Votes on 347 Posts
The rest of the circuit will still communicate with each other.
The local detector will still operate normally.
There is a reason for interconnecting...... to let everyone know no matter where the smoke is.
Make sure you aren't creating a risk by not interconnecting that detector.
Old 10-18-19, 04:46 PM
pcboss's Avatar
Received 30 Votes on 26 Posts
The interconnect should remain connected. You do not want a fire to only alert one unit and leave the occupants at risk.
Old 10-18-19, 05:58 PM
Geochurchi's Avatar
Hi, just curious, why do you want to disconnect it?
Geo
