Spring popped out on GFCI reset
Old 10-20-19, 11:08 AM
Q
Received 1 Upvote on 1 Post
The reset button on a GFCI I have appears to have either broken or the tab or whatever locks the reset button back in place won't hold.
As such, I can't reset my GFCI.
Is there a way to fix the reset button specifically or do I have to replace the receptacle?
Old 10-20-19, 11:17 AM
Received 499 Upvotes on 410 Posts
Replace the GFCI receptacle.
Old 10-20-19, 01:17 PM
B
Received 258 Upvotes on 230 Posts
On many GFCI outlets, power is required to the outlet to reset.
AFJES voted this post useful.
Old 10-21-19, 04:37 AM
A
Received 149 Upvotes on 124 Posts
As beelzebob noted, be sure there is power going to the GFCI receptacle. If no power is present the GFCI will not reset.
Did you remove the GFCI to do something and then try to reinstall it? The power in must be connected to the "line" side of the GFCI. Test for power. If this GFCI is a dedicated receptacle meaning nothing else on it such as a laundry circuit it is possible that the GFCI is fine just has no power and maybe the breaker tripped in the panel.
Old 10-23-19, 09:46 AM
CasualJoe's Avatar
Received 178 Upvotes on 161 Posts
No, on ALL GFCI receptacles they must have power in order to reset.
Old 10-23-19, 05:54 PM
Received 77 Upvotes on 72 Posts
I would not say "all" GFCI devices require power to reset. I have an older Leviton made sometime in the 1980's and it does not require power to reset, however the device does require power to trip with the test button. No power and the test button will trip the device.
