Rough-in connection for gas fireplace
Old 10-21-19, 03:45 PM
Received 1 Vote on 1 Post
Replacing our gas fireplace which was controlled by a wall switch with a new fireplace that has a wireless remote. i would still like to rough in the existing wall switch wiring in case it's needed in the future.
Wiring from wall switch
Wiring that came with the new fireplace
Can I simply connect black to black and white to red here? The new wiring is not terminated.
Old 10-21-19, 07:24 PM
Tolyn Ironhand's Avatar
Received 59 Votes on 52 Posts
Likely Yes. Gas fireplaces are low voltage and use millivolts to turn on and off. Wire color means nothing. You can double check at the switch too.
Old 10-21-19, 09:08 PM
Received 408 Votes on 384 Posts
Usually with a wireless remote you don't have spare connection wires.
Those wires should be labeled. If not on the wires themselves..... check the manual.
Old 10-25-19, 07:36 AM
Ok makes sense. I will check the manual, thanks.
