Changing 4 prong to 3 prong dryer cord
Old 10-22-19, 06:52 PM
I'm changing dryer wire from 4 prong to 3 prong wire.
I can't get the last screw out of the terminal block. It loosened but not all the way and now just turns when I use screwdriver but isn't doing anything. There is a black thing to the right of this screw that kind of feels like electrical tape but I don't see where it connects. I moved the tape over and it didn't allow me to unscrew more.
Any ideas?
Old 10-22-19, 07:09 PM
pugsl's Avatar
Received 25 Votes on 24 Posts
Common problem The connection was loose and heated up. Nut is welded to screw. You will have to replace the Terminal block Post the dryer model # and can lead you to a part.
Old 10-23-19, 01:47 PM
Oh ok. I attached a pic of the model number. I just bought the pair used from fb.
Old 10-23-19, 05:20 PM
pugsl's Avatar
Sorry etes not good enough to read that.Please post it.
Old 10-23-19, 06:10 PM
Received 408 Votes on 384 Posts
GLTF2940ES3 is the washer
GLEQ2152ES0 is the dryer.
The OEM generic part number 134101400. It's widely available.
Quick parts scan
Old 10-23-19, 08:42 PM
Thank you so much!
​​​​​​One more question- how do I remove the old terminal block?
Old 10-23-19, 09:47 PM
In the quick part scan link are several videos.
