Where To Find Sylvania 2 Pole Circuit Breakers
Old 10-24-19, 12:15 AM
I'm planning to install a 240v outlet next to the breaker for a future welding endeavor and want to place a 40 amp breaker.
Which breakers are compatible with this type of breaker. I tried searching around but couldn't find much info on this particular breaker.
6.3.4
Old 10-24-19, 03:37 AM
Inside picture of the breaker
The closest thing I could find was on Amazon:
UBIZ0240-New Zinsco RC3840:
https//www.amazon.com/dp/B000UE45NO/ref=cm_sw_r_cp_apa_i_xNxSDbTN954DF
Would this be the correct one? From the label it says to use RC38 breakers, and this one is an RC3840. Wasn't sure if there's a difference between RC38 and rc3840 models
Old 10-24-19, 06:24 AM
Received 18 Votes on 17 Posts
The breaker you found is correct replacement for that panel.
However, this panel is known to cause fire and replacement breakers are very expansive since they are no longer manufactured.
https://inspectapedia.com/electric/G...tification.php
I would suggest replacing the panel. Looks fairly easy to do so.
Old 10-24-19, 09:01 AM
Received 31 Votes on 27 Posts
Old 10-24-19, 10:51 AM
CasualJoe's Avatar
Received 29 Votes on 23 Posts
UBI manufactures Zinsco style breakers and markets them under the Connecticut Electric name, but I don't believe they are UL Listed. If it were me, I'd put the cost of a new breaker toward replacing that old fire hazard with a new modern circuit breaker panel.
https://www.homedepot.com/p/Connecti...Z240/100669910
https://www.menards.com/main/electri...9218287&ipos=2
https://www.menards.com/main/electri...9218287&ipos=3
Old 10-24-19, 06:24 PM
Thanks for the replies. Unfortunately I'm not in a position to swap out for another breaker bc I'm a tenant renting the garage space, otherwise I'd definitely be changing it to something safer.
Most I could convince them to do was add an 240v outlet, but they don't want to change the whole breaker panel.
