240v Power to 2 Thermostats
Old 10-25-19, 07:17 PM
F
Hi All,
My first post and for good reason...I am totally stumped. I am running a dedicated 240v 20amp line to Box 1 (contains tstat 1). Tstat 1 then runs to baseboard 1. The line then runs to box 2 which has tstat 2 and runs a 2nd baseboard. I just need to know if I wired it correctly. I am getting some wired voltage at baseboard 1 when breaker is on but tstat is off. I attached a diagram as well (sorry if it’s messy). Any help is greatly appreciated.
turns out I can’t figure out how to attach a photo.
Old 10-25-19, 07:22 PM
Received 1,321 Votes on 1,221 Posts
Welcome to the forums.
Follow this..... How-to-insert-pictures.
Your circuit should look something like this....................
If you are using two wire thermostats....... combine all white wires together.
Just the blacks will go on the stat.
Old 10-25-19, 08:32 PM
Received 294 Votes on 253 Posts
What type of stat and what type of weird voltages? Is it a two pole stat or a single pole stat?
