Reload this Page >
70w HP sodium bulb: 4 yrs old. Cycles off in middle of night. Bad bulb?
Old 10-29-19, 10:43 AM
C
70 watt hi sodium barn light with photocell
Old 10-29-19, 11:03 AM
A
Received 110 Upvotes on 95 Posts
good chance it is a bad bulb.
Old 10-29-19, 03:03 PM
Z
Received 412 Upvotes on 367 Posts
I've found that more often than not, if it's cycling on and off, the bulb is going bad.
When the photocell goes bad, it usually faults always on or usually always off.
Old 10-30-19, 10:53 AM
CasualJoe's Avatar
Received 183 Upvotes on 165 Posts
Probably. As HPS lamps get old they draw higher voltage causing them to cycle off and on.
Old 10-30-19, 01:21 PM
Andrew's Avatar
Received 14 Upvotes on 10 Posts
This cycling will also damage the ignitor, which provides the high voltage pulse required to strike the arc within the lamp. Replace the lamp asap, or install a new LED fixture.
Andy
Old 10-30-19, 01:56 PM
P
Received 19 Upvotes on 18 Posts
similar to replacing a 4ft florescent bulb with an LED, if you don't want to replace the fixture, you can buy an LED with the same size/shape base and just rewire the fixture to bypass the ignitor (or ballast for florescent bulbs) and go with line voltage.
https://www.1000bulbs.com/product/212295/PLT-11609.html
consider how often you need to maintain it. If you stay with the Sodium, I would replace the ignitor now so you don't another another trip up the pole or wall any time soon. That is your cheapest parts option (probably under $25). Going to LED reduces your operating costs so a direct wire bulb or new fixture is the other option. An LED bulb with a change in the fixture wiring is next on the cost scale ($50) with a full LED fixture being most expensive ($80-$100). My cost estimates are just that based on quick web searches.
- Peter
