Doorbell
Received 0 Votes
Doorbell
I must be crazy. My doorbell worked fine. My wife wanted a new one, so i told her I would install it. When I connect it, it keeps chiming over and over, but just an abbreviated version of the actual chime. Then when I press the button, it chimes correctly. Here's the rub: it won't work again after that. It's still lit, but when I press the button, no sound. If I disconnect one of the wires, then re-connect it, it all happens again. Totally perplexed. Any advice?
Welcome to the forums.
If it chimes over and over...... it's an electronic chime and probably requires a diode at the pushbutton. It should be talked about in the manual. You can post the model number of the chime unit.
Previous Thread
Next Thread
