What would make a 1 hp single phase motor increase in rpm by 25%
Received 0 Votes
120v -Single phase- no VFD- after years it simply turning substantially faster that if was last week
Received 0 Votes
It could be a resistive neutral at the utility..., do you notice lights getting unusually brighter at times ? Or a resistive neutral on that motor circuit. Check the neutral splices at every switch and junction box all the way back to the panel, including the panel. A resistive ( corroded or slightly loose ) neutral connection can sometimes cause unusually high voltage when another circuit is drawing amperage. It could also be a winding issue within the motor. Depending on how old the motor is, the frequency of use, etc.
Electric induction motor's rotor synchronous speed is determined by the voltage frequency and the number of magnetic poles formed by the stator's run coil windings. If the induction motor is a non-synchronous design, the motor's rotor speed will be less than synchronous due to something called slip. Slip is not a constant and can result in a small RPM change (not 25%). Operating the non-synchronous motor beyond design torque will also cause motor rotor RPM to decrease. What does the motor nameplate state for RPM?
Previous Thread
Next Thread
