Number of receptacles on 15A or 20A circuit?
Old 11-12-19, 03:21 PM
is there a difference in the number of recepticles I can put in line on 15A or 20 A wiring?
Old 11-12-19, 04:10 PM
Received 24 Votes on 24 Posts
In the U.S., no, except for15 amp receptacles on a 20 amp circuit the minimum is two (usually round) singles or one duplex.
Old 11-12-19, 05:57 PM
Received 96 Votes on 88 Posts
In Canada the limit is 12 outlets on either a 15 or 20 amp circuit. An outlet is not just a receptacle. It includes any point that uses power such as lights, fans, receptacles. It does not include switches.
Old 11-13-19, 10:57 AM
A question worth asking:
A (probably 4 inch square) box is fed by a single 120 volt branch circuit and has two duplex receptacle units installed in it. Is this 1, 2, or 4 outlets? (Okay to point out differences for locality, country, etc.)
Old 11-13-19, 12:32 PM
In Canada it would be counted a 2 outlets for the 12 outlet limit.
Old 11-13-19, 05:48 PM
Thanks.
Old 11-15-19, 10:05 AM
CasualJoe's Avatar
Received 29 Votes on 23 Posts
In the US under the NEC the number per circuit is infinite and only determined by load.
Old 11-17-19, 05:56 PM
Would a ceiling light fixture still be considered a single fixture if it mounts to one junction box, but has two or three sockets and bulbs on chains which hang from separate hooks?
Old 11-17-19, 09:25 PM
In Canada a single fixture with more than one bulb is still one outlet.
