Replacing Box - Tips to Make it Easier
Old 11-20-19, 08:33 AM
C
I am replacing a 1-gang box with a 2-gang. There are 2 NM cables that enter from the top and one from the bottom. The cable is from 1986, so the sheath appears to be a bit thicker. Is there any trick to feeding the wires into the box? I'm having so much trouble doing this, and I don't know if I should start from the top or bottom. I was thinking about wrapping electrical tape around the conductors to make them pull more easily through the box. I know this shouldn't be a hard job, but I seem to be struggling with it.
Old 11-20-19, 08:39 AM
Received 94 Votes on 83 Posts
I like to get the cables started into the box before I nail the box into place.
Old 11-20-19, 06:54 PM
pcboss's Avatar
Received 87 Votes on 74 Posts
Since the 2g box will have clamps vs the single gang with open knockouts, assuming a plastic box, you will have to insert the conductors in the clamps and pull until the sheath is under the clamp. You may be able to push one side into the box and pull the last cable in after the box is in place.
Old 11-21-19, 04:52 AM
Geochurchi's Avatar
Received 73 Votes on 69 Posts
Hi, taping the ends of the cables and at the sheath will make it easier, I donít believe there is anything magical that is going to make it easier, just get creative.
Geo
Old 11-21-19, 05:54 AM
T
Received 42 Votes on 41 Posts
possibly use a metal box with cables in the back; using plastic push thru locking bushings. This opens up the sides for clearance to the finished wall.
