Question about Wiring GFCI Outlet
Old 11-29-19, 11:11 AM
C
I am remodeling my kitchen and adding GFCI receptacles. In one of the 2 gang boxes, I have the gfci, a usb outlet, and 3 NM cables (one supplying power and 2 feeding downstream outlets). I connected the incoming hot and neutral to the gfci. From there, I connected the neighboring usb outlet to the load side of the GFCI. On the load side of the USB outlet, I pigtailed the 2 cables feeding downstream outlets. Is that an okay way to wire everything, and will devices on the load side of the USB outlet have GFCI protection (due to the usb outlet being connected to the load side of the gfci)? In retrospect, I probably should have connected everything to the load side of the gfci instead of the load side of the neighboring usb outlet. I appreciate any input.
Old 11-29-19, 11:53 AM
Received 515 Upvotes on 420 Posts
It is OK. The USB and downstream receptacle will be GFCI protected. You can confirm that by pressing the TEST button on the GFCI and the USB and receptacles should go off.
Old 11-30-19, 12:15 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
There is no load side of a USB outlet.
Old 11-30-19, 01:00 PM
Received 294 Upvotes on 264 Posts
I also have never seen a USB outlet with connections marked as a load.
