I cant find the break in the line?
Old 12-06-19, 12:24 PM
biketrax's Avatar
Received 1 Vote on 1 Post
So I was removing an old Bakelite bulb insert. It kind of crumbled and I tripped a breaker. However the noise was just a bit louder than usual. near the bulb insert. When I went to the box to reset the breaker none looked like they tripped. I had never marked this room that was on this line. So I did find the breaker, and half the outlets (Room 2) are working and the room 1 with 2 outlets and 3 light sockets are out! The room that works is separated by a Cement block wall. I checked all the outlets in the room that's out all dead, no hot. I have yet to check the last 3 outlets on the same breaker in the 2nd room with the live connections. Hope I made sense!
What would be the next step before I ask my electrician friend to take a look?
TQ
Old 12-06-19, 01:10 PM
B
Received 101 Votes on 88 Posts
One of the electrical boxes in room 2 that is not working is normally feeding power to room 1. You have to find the last working box and the first non working box in room 2 because this is where your problem is. There is a loose screw or wire nut in one or both boxes.
biketrax voted this post useful.
Old 12-08-19, 06:46 PM
Geochurchi's Avatar
Received 88 Votes on 83 Posts
Hi, is this a ceiling box with the fixture that you removed the socket?
Geo
Old 12-09-19, 06:55 AM
biketrax's Avatar
Geo. YES! A ceiling box in the cement ceiling directly below garage flooring.
Why do you ask? Does it make a difference? Still need to check room 2, sockets are hard to get to need to move some big furniture
