Convert 18v DC power to 12v DC
Old 06-05-01, 04:29 AM
Question
I have a bunch of old laptop power supplies that put out 18v DC at 1.7 amps and I'd like to convert the output to 12v DC.
What's the simplest way to do that?
Thanks!
Dana Brigham
Old 06-05-01, 07:37 AM
There is no good way. That's why Westinghouse won the battle with Edison. In the early 20th century, Thomas Edison advocated DC power. Westinghouse advocated AC power. Westinghouse won in the market because AC voltage could be stepped up and down.
Old 06-05-01, 08:11 AM
resqcapt19
Dana,
You should be able to find a 3 terminal solid state voltage regulator at Radio Shack that will do the job. Make sure that the output current is greater than the load. This is one type of many that are available. Some have fixed outputs others adjustable.
http://www.radioshack.com/product.as...Fid=276%2D1778
Don(resqcapt19)
Old 06-05-01, 06:26 PM
I stand corrected.
