Electrical Hot & Ground Reversed
Old 01-18-20, 08:29 PM
I have a standard plug that is not working. I also have a series of other GFCI plugs not working and a three way switch light not working.
The standard plug shows “Hot & Ground” reversed.
I think the GFCI’s are all in one loop.
I am not a guru at this but after reading other posts I know that these switches and plugs are not stuck in the backs. All newer plugs and switches w/in 4 years. 1990’s built home.
I have voltage meter but honestly no idea how to use it.
Any ideas on tracking down the issue would be appreciated.
Old 01-18-20, 08:33 PM
Received 326 Votes on 281 Posts
Hot ground reversed on those testers often mean an open neutral somewhere.
Start with the receptacles and device closest to the panel. The problem could be in a good working device.
CasualJoe voted this post useful.
Old 01-19-20, 09:27 AM
CasualJoe's Avatar
Received 108 Votes on 95 Posts
Unless I miss my guess you are referring to receptacles. Plugs have 2 or more prongs in a male configuration and get inserted into receptacles.
Old 01-19-20, 11:35 AM
pcboss's Avatar
Received 114 Votes on 99 Posts
Check for a tripped GFI. .
Old 01-19-20, 12:47 PM
Tripped GFCI should kill the hot. If resetting a GFCI fixes it I would be changing the GFCI.
Old 01-20-20, 07:54 AM
W
Received 34 Votes on 31 Posts
Look for black and white wires reversed upstream. The black should be connected to the gold screw and the white should be connected to the silver screw.
Old 01-20-20, 05:00 PM
B
Received 111 Votes on 97 Posts
Is this a new/old problem? If new, was any electrical work done prior to the problem?
Old 01-20-20, 05:05 PM
pcboss's Avatar
Did you check for a tripped Gfi? I have had tripped this open both the hot and neutral.
Old 01-20-20, 05:36 PM
CasualJoe's Avatar
But, if a GFCI receptacle opened both hot and neutral conductors, the plug-in receptacle tester would just be dead and not show anything. The OP says he is getting a hot/ground reverse reading which usually means, like joed already stated, an open neutral.
Old 01-20-20, 07:19 PM
pcboss's Avatar
Thanks CJ, I didn't go back and was using a multimeter to test when I saw the opens, not a 3 light.
