How to extend wiring in-wall (moving outlet)
Old 01-20-20, 09:11 AM
B
Received 1 Vote on 1 Post
Doing a laundry closet reno, and I need to move an outlet down about a foot or so. However, this will require an extension of the existing cable that drops down from the attack - something that is tight as is. What's the best way to go about this? If I splice on another romex extension, can I wire nut and tape the splice, leaving it loose in the wall? Or does it need to be inside a work box inside the wall?
Old 01-20-20, 10:04 AM
Received 249 Votes on 219 Posts
The junction needs to be in an accessible junction box with a cover.
It can not be buried or hidden inside the wall.
Old 01-20-20, 10:10 AM
Z
Received 112 Votes on 104 Posts
Easiest way is probably to leave the current box where it is, splice in a new cable there down to the new receptacle box. Add a blank cover plate (or leave the existing receptacle) for that splice box.
If you don't like the box in that location, you can follow the cable up the wall or into the ceiling and put the splice box anywhere it fits - and is still accessible.
Old 01-20-20, 11:15 AM
P
Received 100 Votes on 80 Posts
If this a 120V 20A or less outlet you can also use a Tyco NM (Romex) splice kit (no box needed).
Old 01-20-20, 11:32 AM
B
So even if the tyco splice kit is in the wall (inaccessible), that's still all right? If so, that sounds like the way to go.
Old 01-20-20, 02:54 PM
P
The Tyco splice kit is allowed to be within the wall without access per the NEC.
Caveat: Wording in the NEC allows it to be concealed when used for repairs of wiring in existing buildings. It's gray to say you are doing a repair. See NEC 334.40(B)
