Proscan plded3280a - Standby light continues to flash
Belongs to friend of mine. Exhausted every means; the standby light is flashing. I've checked the voltage via Meter, it is fine. I've checked and inspected all Caps, it is fine. Used both direct connect and the power supply (surge protector); just in case it might be the power supply board. Same thing, red light continues to flash. Disconnected, left overnight after all (side pan) options to reset failed. I am trying to locate the tiny little "reset" button (typically found near CNTL PAN) or near the connection. There isn't any. This unit is about 3-4 months old. I would need to know if power supply is shot, or defective; or worse, both power supply and mainboard is shot (have to tell them to get a new PLED).
Thanks!
Thanks!
