14 awg wire from overhead shop light hardwired
Hi, I have some overhead led shop lights I have strung together. I want to cut off the plug (just a normal 2 prong) and hardwire it to the outlet it would plug into. Standard 110 outlet. I'll have to check, I'm not sure if it's on a 20amp or 15 amp circuit. The wire running to the plug is 14 awg......i don't see how this would be any different than just plugging it in..... But thought I'd check in here first in case I'm being silly and missed something.
Thanks!
David
Thanks!
David
Received 273 Upvotes
Wirepuller38
This wire would become part of a branch circuit. Different rules apply to branch circuits vs. appliance cords concerning the type of cable allowed.
Add another receptacle in a more convenient location and plug them in. Do not cut the cord and off.
I think it is a bit of grey area. Even if the light is hardwired, if the light was meant to be installed in this manner, it should be allowed. Some under cabinet lights fall under this.
I also have seen grid panel lights (for ceiling light tracks) with 16 AWG pigtails. Those lights are meant to be hardwired to a junction box.
I don't know if cutting a plug off and hard wiring will be considered ok, although it is not really any more dangerous than lights with pig tail.
One thing to note; The modification described is happening "outside the device", and involves a permanent attachment to the building wiring. Via, a clamped cord into a building's outlet box. Although, electrically, the cord and plug connection is the same as the same cord into a box directly, other risks emerge. Someone could extend the cord to a high current device beyond the cord ampacity, and now, there is no local disconnect; both can be viewed as diminished safety.
