In ProcessAdSlots.php line 39: Trying to access array offset on value of type null
Power for one breaker won’t come on
Old 02-06-20, 05:26 PM
I had an outlet that was not working in the basement. I turned off the breaker and went to change it out. Started to unscrew it, then changed my mind. I put the cover back on and turned the breaker back on. I then went to another part of the basement and turned a lamp off. Right away all the power on that breaker went off. Checked the breaker, it was not obviously tripped. I flipped it off and back on, nothing happened. Tried one more time and nothing. The electrical panel is all brand new, we had it installed about a month ago. Did the breaker blow? Could it be something else?
Old 02-06-20, 05:45 PM
Received 299 Votes on 256 Posts
Are you sure it is the correct breaker?
Might not be the breaker that is the problem. Might be a loose connection on the circuit.
Old 02-06-20, 05:50 PM
I’m sure it’s the right breaker, we labeled them all when we put in the new panel. Plus i successfully turned it off to change out the plug and turned it back on before it went black.
