Wiring diagram help
Old 02-06-20, 06:08 PM
P
Wiring diagram help
Which wires on the motor do I need to swap to reverse the motor polarity?
Diagram
Old 02-06-20, 06:39 PM
Received 491 Upvotes on 403 Posts
Find someplace else beside photobucket for your image. I'm not turning off my adblocker for them.
Old 02-06-20, 07:04 PM
P
I think I fixed it sorry.
Old 02-06-20, 07:34 PM
Looks like some sort of stepper motor. Not a simple wire swap to reverse. Is there any info on the motor itself? Maker? model#.
Old 02-07-20, 05:04 PM
Received 3,485 Upvotes on 3,128 Posts
That is a dual source three phase motor. It should have reversing built in to the circuitry.
Technically swapping any two input wires will change the direction.
For example.....
U1, V1, W1 ...... reverse U1 and V1.
U2, V2, W2 ..... reverse U2 and V2.
It would be nice to know what that unit is.
Old 02-07-20, 06:00 PM
To reverse a three phase motor simply swap any two of the hot power leads.
Old 02-07-20, 06:13 PM
I agree Joed. One problem is there are two sets of motor windings.
Do you swap one pair of each set of windings ?
Or is one set for forward and one for reverse ?
Old 02-07-20, 08:15 PM
I have no idea what that device is. I just know that to reverse a three phase motor all you do is swap two of the hots.
Old 02-08-20, 05:44 AM
Z
Received 372 Upvotes on 332 Posts
Looks like it is (or was?) a super duper food processor
https://www.restaurantsupply.com/robot-coupe-blixer-5
For what it's worth, the marketing docs refer to it as an induction motor.
No idea what that means electrically though.
Old 02-08-20, 08:09 AM
That is one heck of a food processor with a 3HP motor.
Blixer 5 - 3 HP, three phase, two speed, 1725/3450 RPM
I have to ask why would you want to reverse the direction of the motor.
Regardless of the reason reversing two supply power leads should reverse it unless it has some sort of VFD motor controller.
